When I open ZBrush and Lightbox appears there is a heading called ‘Spotlight’.
How do I load my own Spotlight folders (or ‘shortcuts’) into Lightbox so that when I select Spotlight, my own folders appear?
Thanks!
~S.~
Thanks!
~S.~
If you create a folder called ZSpotlights in the main ZBrush 4R6 folder you can then store your Spotlight files there and they will show in Lightbox under the Spotlight tab. You can also put a shortcut in that folder for any other folder you want.
Thank you! ~S.~
