Split Screen
I want to resize a tool in the Split Screen without affecting the size of the second tool. How do I achieve this?
Hello @sculptingisawesome
If you mean you wish to physically transform the active tool, just use Gizmo.
If you mean you wish to zoom the camera to make the object larger in the viewport independent of the other view, I’m not aware of this being possible with the Split Screen tool. That would require multiple cameras, and split screen basically applies the same camera to objects on different parts of the screen.
Zbrush has many ways to work with reference, if that is your goal. Another may fit your situation better.
Remember you can always “snapshot” (shift + S) a view of any model at any size/angle to the canvas as Pixols, and then sculpt right next to it. Ctrl-N clears the canvas.
