[ SOLVED ] - Custom UI hiding buttons
Monitor is 1920 x 1080
ZB UI Customize = on pushes expose button off screen.
when customize UI is off, the button is visible but not in a good location.
Anyway to get around this without deleting and creating a new custom UI?
zb2019_offScreenButtons
Hi @CountQuadula
  • When you enable customize, the UI reverts to a neutral position allowing you to move UI elements wherever you want. If you don’t like the position of a button in its normal position outside of customize mode, then simply move it and re-save your UI. You dont need to re-create the entire UI from scratch.
  • During normal operation, opening and closing certain UI elements like the side trays can cut off certain buttons if they were not placed with those elements in mind.
  • If a button is ever cut off by the screen edge, you can scroll that row of buttons by mousing over the UI panel that contains it until the cursor changes to to an arrow icon, then Ctrl-dragging on that row of buttons to slide them back and forth.
  • You can reduce the size of the buttons in order to fit more of them on screen at once, in Preferences > Interface> UI > Button Size. You will have to restart the program to see the changes. Remember to Store Config after making changes in the preferences for those changes to be remembered at startup.
THAT is the info! “Ctrl-dragging on that row of buttons to slide them back and forth.”
thanks!
