SnapToSBox
Under the Draw Pallette, is a button named SnapToSBox. I read the documentation, however, I still am unsure of its function. Can anyone help me?
Hi @Lupus
It is so the reference grids can be used in conjunction with the ShadowBox. With the SnapToSBox button enabled, it will snap the grid size to the same size as the ShadowBox in case you want to use any reference images to draw your masks. That whole section in the Draw palette is for using the Grid function.
Thanks ZBER2. That explains a lot.
