Hey Guys,
I have a question about the smooth tool. It seems that at times the smooth tool gets really weak (un-cool) at higher sub-d levels even if I crank z-intensity to 100. I can usually fix the problem if I jump down to level 1 then back up again. But at higher mesh resolutions this is becoming time consuming. Do you all run into this one? Is there a way around it? Am I doing something lame?
Thanks!
Adam
Oh, and I did try this but it didn’t seem to work:
There are two ways to smooth your models:
