When I use Smart ReSym, it doesn’t correct the center line of vertices:
However, it reports that full symmetry was found, and it does correct all other vertices.
I have tried the following:
- Smart ReSym at each subdivision level, starting at the lowest and working up (no change in results)
- ReSym (does not correct symmetry and reports incomplete success)
- Mirror and Weld (makes center line symmetrical, but usually modifies topology, which is unacceptable)
