Inspired by Froyd’s natural wood i tried to make a "sort of " natural woodmaterial,…it’s “sort of” because i did not use woodimages but just a small image made with a digital camera , i believe it was an apple,…and i wanted to keep the material small !
i you replace the small texture-maps with real tree & bark images it must look even more realistic.
By using the intensity ans saturation sliders in S1 you can turn it from brown wood to a more greener wood, and you can use it in combination with a texturemap !
and here’s the material
The material is made at a 1280 X 960 canvas…and a canvasbump-size must be set higher or lower if you want to keep the material in proportion !
To get a stronger wood set the canvasbump slider in S4 to 10 !
