SliceCirc quesiton
hi
i was watching Paul Gaboury’s video where he uses SliceCirc to add 4 symmetrical circle polygroups to the front of a polysphere.
http://info.uartsy.com/paul-gaboury-powerful-brushes.html
(happens at around 3:09)
i tried to recreate what he did but SliceCirc always slices through to the back of the polysphere, where the front and back both has a circle polygroup. Unlike Paul’s video, when he did it, only the front of the polysphere was affected by the slice, the back did not get affected.
I tried hiding the back half of the sphere, which did not work. Also tried masking the back, although the polygroup was not added at the back, I can still see the outline of it at the back.
thanks in advance!
I’m confused, he’s not doing anything like that at 3:06. He’s polishing edges.
However, if you use slice circle or curve or square it only works on the visible polygons. So, if you hide the back, it should definitely work. I do it all the time.
ah just realized there are multiple videos on that page which are different depending on which chapter you’re on.
Thanks for your help Gordon!
