Slice/Cip/Trim Curve Brush Feature Request
I am not sure if this is the appropriate place to post this request but hopefully it is.
The clip, trim and slice curve brushes are great and I used them often but find that the curve interpolation (the way the curve bends and smooths) is not as accurate as I wish. It would be great to have these brushes have an interactive nature to them where you could adjust the curve making the slice. Or even having controls on the curve that are similar to vertices or bezier handles. In cinema 4d for example there are linear curves, cubic curves, etc. You can adjust the degree of influence of a point on the curve giving you precise control over the curve itself. It would be great to have that functionality in these clip, trim and slice brushes. I know you can get a linear curve with these but have a slight curve that doesn’t overshoot would be great!
Thanks!
