Size slider location please?
Please could you tell me where is the Size slider mentioned here:
  • =left]Size and Position of the Tool can now be adjusted through dedicated sliders. Unlike the deformation sliders which reset to 0 immediately, these new sliders retain their values. For example, you can simply set the Size slider to 2 and double the size of your model. To change it back to the original size you would change the slider back to a setting of 1.
  • =left]from http://pixologic.com/zbrush/features/ZBrush4R5/additional-changes/
Thanks. Found it at the bottom of the Geometry panel.
