AS you will probably understand from the title, I want to create a mask with CanvasClick/Stroke but I can only mask with Control (sticky) pressed.
Is there a zscriptcommand to IPress (and later: IUnPress] this Control-key, so it is not combined (as in KeyPress) with an abc…-key, but just by itself, and stays pressed until unprees when the maskingactivity is done.
THe same question for Control+Shift, needed for hiding/showing.
If this is possible I’ll be able to offer a nice new plugin.
Greetings, EddyL
