Silberdenar Thanks so much!
mutte696 Thanks!
Gordon Robb Thanks! Yes the Helmet was a separate object (I made a very simple basemesh in 3ds max) then all the details were done in Zbrush! not all the geometry was intersected but a good part of it! the helmet was printed separately!
marianosteiner Thanks!
Thanks Greg! yes I can’t wait to get those babies and the dio
Merci Guillaume!
Thanks majid!
Santis Thanks!
darkmummy Thanks so much! but he can’t twist glass or plastic only metal!
Thanks so much Raf!
pimeto Thanks! for the texture it wasn’t hard since it was just in the front that I needed it! I just found some carbon fiber textile on the net made it tile in photoshop and then made a bigger tiled texture in photoshop and applied it. you can also do uv’s and use a tilable texture and then mask by opacity and inflat in deformation!
jmenna Thanks! Yes the head does a really big change in the mood and the way the shadows falls on his face would have made him look very different! This piece was 3d printed with a high resolution printer but Adam Ross would know more about this part! it’s half size 1:2
vikramvr Thanks so much!
