Sickle old man
2D conceptual design originated from Chengdu Designer: geyijiu, microblog:
https://weibo.com/u/5129941109?tabtype=album
Work name: sickle old man (original work name sloth)
The models are all made in ZBrush,
First, use the real-time cabling function sculptrispro to quickly build the basic model,
Then use zremesher2 0 recalculate the model surface wiring,
Next, use the zmodeler function to adjust the local wiring, and then subdivide the engraving.
The garment is solved by marvelousdesigner and then imported into ZBrush sculpture.
The exhibition uses the bridgerizomuvzbrush plug-in,
ZBrush generates normal and displacement maps,
The prop mapping is completed in the substancepainter,
The sculpted details and mapped details of the face are combined with zwrap plug-in and Mari,
Xyz2 is used The details provided by the 0 map.
Rendering is done using Arnold in Maya.
Use Photoshop color matching later
web:Beerus_ Y wechat: 18292002820
cool model! :slight_smile: I love the concept and the name “sloth”.
