Shortcuts adjutment
Hello everyone. I want to set shortcuts brush parameters like zIntenzity, but no only slider, but with scrolling like shortcuts brackets to set draw size. I think it is save in C:\Users\Public\Documents\ZBrushData\ZStartup\CustomUserInterface4R7.CFG. I open this file in notepad and it is showing me this (on image)
I buy wacom intuos and want to use Touch ring for this.
I am not english man so sorry for grammar.
You can’t edit a configuration file.
In order to use hotkeys to change ZIntensity and Focal Shift in the same way as the bracket hotkeys for Draw Size you will need a plugin.
There’s a plugin by Wyrdesigns here that will do the trick. Simply unzip the file and then copy the HotkeyFocalS_ZInt.zsc file to your ZStartup/ZPlugs64. It will add buttons to the Zplugin>Misc Utilities menu just like Draw Size which you can then assign hotkeys to.
http://www.zbrushcentral.com/showthread.php?172391-Useful-small-ZScripts-and-Macros-for-ZBrush-4R7&p=1013109&viewfull=1#post1013109
