Shift key does not smooth
Shift key (Mac) worked initially for smoothing. Now when I press it to smooth I get ‘SelectRect’. Any ideas?
That means that the Command key is also being pressed, is perhaps stuck or is being triggered by another application in the background.
Shift for Smooth and Cmd+Shift for Select are hard coded into ZBrush. They can’t have accidentally been changed by you or any plugin, etc.
