Hey together,
- this UI is made for 1600x1200, you will miss some buttons on the right if you use a smaller resolution!
- UI uses Marcus
[Alpha/Texture Loader plugin](http://www.pixolator.com/zbc/showthread.php?t=30425) - and some of Svengalis QuickSave plugin
- some buttons are macros that replace native buttons for size-reasons, they dont reflect if the original button is enabled or disabled - keep that in mind!
click the image to download:
- to make as much UI space (width) accessable as possible, move the very thin button in macros->frd_ShelfUI and place it left in both, left and right shelf. that will make them smaller again and let you access the most right UI areas
- Dont create buttons that have a width below 38. Buttons below that size and all buttons alligned right to it somehow move on pixel to left-top every time the config is saved and ZBrush is restarted - using a button with a width of 15 a placeholder between the different buttongroups would destroy the leayout more and more with every UI-save
