I’m getting more into ZBrush again and encountered a few possible problems concerning curve mode / curve brushes with ZBrush 2020.1.4.
When sculpting on a surface, they work ok when using the mouse, but go crazy when using a pen with activated pressure sensitivity (that works well otherwise in ZBrush).
I can drag the curve out just fine, but when it comes to applying it by dragging on the curve, it throws lot’s of crazy coils/spirals/waves, many of them detaching from the surface as if the curve got a lot longer and needed to account for that (no matter if the start and/or end point are fixed or not). This happens pretty much immediately, so dragging out a shorter distance, even much smaller than with the mouse, doesn’t help.
Activating Liquid does help, but this seems to be a bug related to pressure sensitivity to me. (Anything less than full pressure throws those curves by making the base curve a lot longer than the motion would account for.)
Does anyone else encounter the same?
Generally, the system of manipulation the curve and “applying” it with the same action/motion seems cumbersome to me, to be honest.
Both with mouse and pen the curve is sometimes subtracted from the surface instead of adding to it and I can’t quite pinpoint when that happens.
I can’t seem to find these settings described in the reference guide:
“The amount of bend at the cursor location is defined by the Curve Falloff settings, located at the bottom of the Curve menu. A Curve Falloff which has the point at the top left will produce a rounded curve deformation while a curve falloff which goes to the bottom right of the curve line will produce an angular curve. Bend mode is enabled by default.”
There is a Curve Falloff in Curve Modifiers, but that seems to be for Intensity/Size and doesn’t seem to affect the falloff of the bend.
Has this been deprecated and replaced e. g. with FocalShift?
Then, is there a way to adjust the curves for Intensity and Size separately? E. g. if I want a curve to get wider and flatter towards one end?
Lastly turning on Backtrack in LazyMouse and then deactivating LazyMouse still keeps Backtrack active with Curve Mode
Generally, what is the best method to report bugs? Here in the forum or directly to support? Will moderators log bugs reported in the forums?
Is there some kind of public bug tracker to check if a problem has already been reported besides doing a search in the forums?
