Set variable for current selected subtool
I’m trying to set a variable for the current selected subtool. But I’m not able to get it to work. I want the script to go through every subtool and check whether it’s visible or not.
The following zscript is my attempt at storing the subtool name.
 [Loop,1024,
 	[VarSet,SubToolTitle,[IgetTitle, Tool:Current Tool]]
 	[If,[IModGet,Tool:SubTool,SubToolTitle] >= 7,
 		[IColorSet,255,0,0] //Red Debug Color
 		[IColorSet,0,255,0] //Green Debug COlor
 	[If,[IsEnabled,Tool:SubTool:SelectDown],
 		[IPress, Tool:SubTool:SelectDown]
 		,//else no select down so end of subtools & exit
 		[LoopExit]
 	]//end if
 ]//end loop
This however works with the DemoSoldier_1:
  [Loop,1024,
  	[If,[IModGet,Tool:SubTool:DemoSoldier_1] >= 7,
  		[LoopExit]
  	]//end if
  ]//end loop
I think I’m slimpy failing at trying to replace “DemoSoldier_1” with a variable.
Any ideas?
Thanks!
You need to use [StrMerge] in order to use the variable in the subtool path. Also, note that in 3.5R3 the Mod values have changed because of the Remesh options - you need to use >= 16 for visibility.
[Loop,1024,
 	[If,[IModGet,[StrMerge,"Tool:SubTool:",SubToolTitle]] >= 16,
 		[Note,[StrMerge,"\Cff9923SubTool named \Cffffff",#SubToolTitle,"\Cff9923 is visible"],,1]
 		[Note,[StrMerge,"\Cff9923SubTool named \Cffffff",#SubToolTitle,"\Cff9923 is \CffffffNOT \Cff9923visible"],,1]
 		[LoopExit]
 	]//end if
 ]//end loop
D’oh! Of course! Thanks a lot!!
