set Display Properties to Double
is it possible, or is there already, a zscript to set the Display Properties to Double on Startup ?
The “Double” setting is on a per-subtool basis so there’d be no point in setting it at start up. Why don’t you assign a hotkey to the button, if you find you are using it a lot?
TYVM. HotKey it is.
