Hi! There is some way to send a file by email via script or another language?
thanks in advance!
thanks in advance!
I recommend python for that, so you just export the content for the mail using ZScript, and then run a python script, using [ShellExecute] function. here is a python tutorial :
Hope it helps,
Nicolas
thanks a lot Nicolas, Im going to check this technique!
Hi Nicolas,
Would be possible to check if I got what you meant?
So, I should:
By ZScript:
and then:
By Python:
2) use [ShellExecute] to run a whole python code which will attach the file in the email and then send it.
thats correct?
thanks Nicolas!
zscript :
python :
Hope it helps,
Nicolas
Thanks a lot Nicolas!
