Selection and Mask outside of the document
Hello there. I was wondering what was the reason for disabling the ability to Ctrl and Ctrl+Shift click/drag outside of the document to invert/reveal selection and mask?
It was an option for more than a decade, leading to a strong habit. It was allowing to perform aforementioned modifications to selection or mask without even watching where do you click. With latest versions of ZBrush you are now forced whether to look at an empty space not occupied by a model or, when zoomed in, to use the document’s perimeter behind the frame. It’s really annoying and is the reason I don’t want to switch to newer versions. Is it possible to make an old behavior at least optional?
Thank you
Hello @Vir_Norin ,
Feature requests can be submitted at ZBrush supportand are likely to be missed if made any place else.
Thank you!
