Hi marcus,
sorry - i accidentally posted this in the wrong thread. i´m on the full Zbrush version 4r8 here.
what you wrote was the same what i was thinking:
I heard about that OS X handles the internal memory / cpu usage etc. with a „clever“ management in
the background and „shuts down“ other - not used applications when there are some open
windows in the front or when in fullscreen mode.
So the developers of zbrush aren´t the ones to blame.
Concerning the ui - i transfered my custom ui from earlier Zbrush versions to the new 4r8.
I´ll take your advice and will rebuild the ui new - i also thought about that this could produce
the strange behaviour.
i´ll let you know when i did this and if the error still occurs.
one thing i can tell you at this point: if i start zbrush - windowed mode - the problem is there
that buttons are offset
if i switch to fullscreen mode - and then back to windowed mode - the alignment of mouse / underlying
buttons is back to correct and works - maybe this helps the developers to narrow down the „error“
maybe this behavior is different on more modern systems / screen setups with eg retina displays ?
It is basically not a big deal - i don´t use see through that often - but pixologic gave us so much over
all these years - when i can help even it is only a little bit.
thank you, cu you later & kind regards
Ollie
