SDIV slider not enabled although I didived
Hello!
I have divided my model, but the SDIV slider doesn’t become enabled.
Does anybody see why?
Edit:
Solved:
After I removed all masking, it worked.
Thank you!
Hello @AC2015!
Your mesh appears to be partially masked. If you subdivide when partially masked, the mesh will only be partially subdivided in the unmasked areas. This does not create a new subdivision level, so no SDiv slider.
Clear any masking, then subdivide again.
