I’ve read over the past few years that a lot of people are having the same issues with Sculptris Pro brushes(even the standard brushes) lagging once the model reaches around 300,000 polys. I was messing around with it last night and figured out that if you turn on “Fast Samples” (Brush>Samples>Fast Samples Button) that lag doesn’t present itself until about 1.5 million polys. Hope this helps anybody running into that same issue.
Please direct any technical issues you have with ZBrush to Pixologic Support. Technical Support for ZBrush is not provided on the community Usage Questions forums, and technical issues reported here may not be noticed by the developers.
Thank you!
