Sculpting Afrter using Zremodeler?
Is there a way to? I dynameshed and turned my model into a polymesh 3D? I can not get it to apply the clay build up or the standard brush. I divided and applied, and nothing works unless there is some order or trick that I am unaware of. The move brush works, I can go the old fashioned rout. I would just like to know if and how it is possible.
That should be completely possible, I would make sure you haven’t masked something, or that you haven’t switched to a different subtool if you have any.
All you are doing with ZModeler is working with another brush, once you are done with it you should be able to sculpt as normal.
Rookie mistake. I was used to the zmodeler tool, that works with spotlight on. Is there a way to work with some art work I made up on the canvas or do I just need to go back and forth?
