scripting tutorial
hello,
i dont know how to script, i have downloaded the "restore symetry " zscript, i want to know how to use it,
thanks, Foo
Which ‘restore symmetry’ script are you talking about? Can you give the link? Some zscripts are for earlier versions of ZBrush and won’t work with the current version.
ZScript version 1.5.1 by Dave Bushnell,
this is the script, thanks for responding, i will read the stickys next time,especially the “read this first” part,:idea: i just saw your links to the tutorials,
Foo
OK, that won’t work in ZBrush 3.1 as the ZScript commands for ZSpheres don’t function properly. I did produce a workaround version but if you use it be sure to back up your model first and follow the instructions:
http://www.zbrushcentral.com/zbc/showpost.php?p=573860&postcount=7
If you want to learn about zscripting then the wiki is the place to start:
http://www.pixologic.com/docs/index.php/ZScripting
thanks for the script, it worked just fine, i am just starting to get some results w/ zbrush, i have had it for years but i use several other apps. and havent had the time to learn ZB.
thanks for the links also.
Foo
