Couple of questions about scripting lights:
I take it that the “Light Placement” variables are azimuthal angle (θ), and polar angle (φ)?
How can you determine if a light is on or not - in order to switch it off or on as needed?
I’m not sure of the correct syntax and can’t seem to find it in the docs - light enabled? light = true?
Are there 32 lights or just 8?
As recording a macro just comes up with “Light Switch” pressed/unpressed which doesn’t help?
Cheers
