Greetings. I’m new to zbrush and scripting all together. I put this together to simplify all the subtools of a model. I recorded the commands and frankensteined some I found online. I’m sure there is some simple mistakes but I can’t quite figure them out. Any help would be appreicated. Here’s the script as-is now. Also, If anyone knows how to deal with popups during scripts I would appreciate that
[RoutineDef,“Low Res”,
[If,[IsEnabled,“Tool:SubTool:SelectUp”],[SubToolSelect,0]]
[Loop,10000,
[Loop,10000,
[VarSet,activeSubT,[IGetTitle,Tool:Current Tool]] //set variable name for current subtool name
[IModSet,[StrMerge,“Tool:SubTool:”,#activeSubT],17] //show current tool
[IPress,Tool:SubTool:Duplicate]
[IPress,Tool:Geometry:Check Mesh Integrity]
[IPress,Tool:Geometry:Fix Mesh]
[IPress,Tool:Geometry:ZRemesher]
[IPress,Tool:Geometry:Divide]
[IPress,Tool:SubTool:ProjectAll]
[IPress,Tool:Geometry:Lower Res]
[IPress,ZPlugin:UV Master:Unwrap]
//NOTHING Happens after this
[IPress,Tool:Geometry:Higher Res]
[IPress,Tool:Displacement Map:Create DispMap]
[IPress,Tool:Normal Map:Create NormalMap]
[IPress,Tool:Texture Map:New From Polypaint]
[IModSet,[StrMerge,"Tool:SubTool:",#activeSubT],1] //hide current tool
[IPress,"Tool:SubTool:Selectup"]
[VarSet,activeSubT,[IGetTitle, Tool:Current Tool]] //set variable name for current subtool name
[IPress,"Tool:SubTool:SelectDown"]
[If,[IsEnabled,"Tool:SubTool:SelectDown"],,[LoopExit]]
[If,[IsDisabled,"Tool:SubTool:SelectDown"],,[LoopExit]]
[ISubPalette,“ZPlugin:Ugly Low Res”]
[IButton,“ZPlugin:Ugly Low Res:Low Res”,“Hit it!”,
[RoutineCall,“Low Res”]
,1.0]
