I am trying to write a scrip to get the value f the Tool:Geometry:XYZ value and multiply it by two. I wrote this but its not loading, can some one tell me whats wrong with it . Thanks
[VarDef,size,0] //defines a variable to store Edit mode
[IButton,“SCALE UP”,“Scale X 2”, // creats button
[VarSet,size,[IGet,Tool:Geometry:XYZ Size]] //set variabel to size
[ISet,Tool:Geometry:XYZ Size,(size*2)] // multiplt scale by 2
Update to original post:
So I changed the button name of this script to testup
[IButton,“testup”,“Scale X 2”, // creats button
when I use rload all macros the button does not show up as before
but if I load the script from the script palet
the button shows up in the script editor and the script work
but how can I get the button to y interface? I guess some thing is still wrong with the sript?
Update two"
So in experimenting with this I looked at a script I recorded in zbrush and substituted that format (took out the button line) and ended up with this which loads the button into the macro pallet and the script works. So If some one can just explain what I did wrong initially I would appreciate it, Thanks
Good working script:
//ZBRUSH MACRO - Recorded in ZBrush version 2021
[VarDef,size,0]
[IButton,???,“Press to run this macro. Macros can be aborted by pressing the ëescí key.”,
[IShowActions,0]
[IConfig,2021]
[VarSet,size,[IGet,Tool:Geometry:XYZSize]] //set variabel to size
