After the great pluggins rleased by Ryan, allowing to diplay high view of alhpas, I was wondering is it could be possible to make the same script, but to display a high size curve viewport.
I often use curves to ajust materials settings, but also for alphas. For that, I need precise adjusts but the size of the curve window (even when zomming in), make precise adjuts difficults sometimes…
Hi Sebcesoir,
Although it would be possible to make a script to display ZCurves larger - in ‘library’ form in much the same way as the Alpha script - I don’t think it would be all that easy (and perhaps impossible) to write a script so that you could adjust the curve in the larger view.
Edit: You can, of course, Ctrl+drag the Zoom window to next to the curve you’re adjusting (I put the palette on the left shelf for ease), and then increase the zoom up to x8 by clicking the x2 number.
