Finally, it is the turn of Sci-Fi material. In this part of the designer training series, we will build a padding wall that can be used in spaceships or their stuff. An important event in this part of the tutorial is using external software to develop our resources. The best thing is to understand the relationship between other software and the designer because the designer will always make not everything. So let’s start learning how to make the Sci-Fi padding wall in substance designer and marvelous designer!
More Info:
https://www.artstation.com/a/16161943
Contents:
- 200 minutes of unnarrated videos
- 1080 Resolution
Chapters:
Chapter 01- in this chapter, we start our work with primary nodes, create our structure in substance designer, and add all the details we want. We will add the padded wall to our graph and finish our work in the height stage!
Chapter 02- this video shows you how to plan, model, and prepare our padded wall resource with a helpful technique! We start our work in 3dsmax and prepare the model for the marvelous designer. And after that, start our simulation with the marvelous designer! In the end, we create a padded alpha/ pattern for our graph in ZBrush.
Chapter 03 - Continuation of the previous part, we worked on the color and made custom decals and items for the material. And after creating our roughness and metallic data, we will add more details in color and prepare emissive channel data at the end!
Software Used:
Substance Designer
3ds Max
Marvelous Designer
Zbrush
Level:
Intermediate
Prerequisite Basic knowledge of Substance Designer, Zbrush, Marvelous Designer, And 3ds max or any other DCC
Attention: clean SBS file is included in this product that you can study over that (version of the designer should be 11.3 or above)
Attention: all videos are unnarrated (it means there are no voice-over videos or subtitles)
Do you want it?
The other products too:
Metal Railway Tutorial - VOL 08 :
https://www.artstation.com/a/16017894
Broken Roof Tiles Tutorial - VOL 07:
https://www.artstation.com/a/15815559
Metal Retaining Wall Tutorial - VOL 06 :
https://www.artstation.com/a/15570800
STYLIZED PAVEMENT WITH MOSS Tutorial - VOL 05 :
https://www.artstation.com/a/15406536
Stylized Plaster Wall Tutorial - VOL 04:
https://www.artstation.com/a/15331498
Handmade Mosaic Tutorial - VOL 03:
https://www.artstation.com/a/15064540
Damaged Concrete Tutorial VOL-02:
https://www.artstation.com/a/14950781
Broken Tiles Tutorial - VOL 01:
https://www.artstation.com/a/14922290
Facade In Substance Designer Tutorial:
https://www.artstation.com/a/5308958
