hello, when i use scale master, zbrush scale unify it sets xyz to 2, but it also changes the scale factor under tool exoprt. does changing scale factor affects how dynamesh or brushes behave?
if it affects it can i just manually set it to 1? or instead use unify under deformation? since it does the same operation but it doesnt change scale factor.
thank you
