How can I export a mesh in stl while keeping the correct/new scale I’ve given it with scale master? I used scale master to resize a bust to 5inches but in the 3D export plugin if I update the size ratio it doesn’t give me the correct scale.
No one?
They should agree, so long as you pressed the “Resize Subtool” button in Scale Master. Then when you press 3DPrint Hub “Update Size Ratios” make sure you select the correct option.
