Hello,
i want it to scaled the ploygons one by one when i select polygons (like a construction of a keyboard for example)!
Tastatur|1000x380
You can use the ZModeler brush > polygon actions > scale, with “single polygon” selected as target, and scale the first polygon. The ZModeler brush will remember the amount of scaling and repeat it on the next polygon by just clicking on it.
If you want to scale all polygons at once you can make a polygroup for the polygons you want to scale, make a mask from that, then in the geometry tab of the tool palette go to the Deformation menu and use inflate. You can choose the axes for each deformation for additional control by checking the xyz option to the right of each deformation.
