Saving and loading multiple custom brushes?
What I hope is a simple one…
If I save a brush using a custom alpha and texture, I can reload it and it works fine.
But if I create and save a second brush, again with custom alpha and texture, it uses the same alpha and texture
‘slots’ as the first. Loading it replaces the alpha and texture in the first brush.
This means I can only load and use one brush at a time.
Is there a way to have both (or even multiple) custom brushes load together and work correctly?
Thanks.
G.
You can save custom brushes to the ZStartup\BushPresets folder and they will then be available when ZBrush starts. Don’t overload the folder though as this can impact of ZBrush performance - about 25 files max.
See here for more info on user content:
http://docs.pixologic.com/user-guide/customizing-zbrush/user-content/
