Save Error
I’m having a problem using the SAVE button. I’ve emailed tech support twice but they’ve never gotten back to me. Essentially, I need to use the SAVE AS as a work around because I get this error message whenever I use SAVE:
Internal Error Afile.ccp. Line:454
Unable to open/Create a file
-:1\46979\ZbrushdocZbrushdocTEMPLATE 1.ZBR.ZBR.ZBR.ZBR.ZBR.
I hate to use this forum for this type of technical stuff, but I need someone to get back to me.
There will be an update patch in a few days that will correct this error. In the meantime, you can use the workaround of using the “save as” button instead of “save” which should work fine.
Thanks for the info!
