Hello,
i am trying to paint on a model with projection master, and i want to run a second script at the same time, which allows me to use a palette. But it seems that every time, when i activate Projection Master, the other script seems to be gone …
How do i run two scripts at the same time? What is it what i am missing here?
Heiner
All you need to do is recall the palette script by pressing its button or hotkey again. You won’t affect Projection Master; simply press the Projection Master button or hotkey ‘G’ when you want to pick up your model.
