Figured I’d post on a couple of irritations I have with 3.X. Can’t find any
other seach hits on them. Here’s the first…
When rotating a tool under edit, the shift key can be used to snap to
the nearest 90-deg step. With ZB2.0 this worked beautifully.
Snap behavior under 3.0 and 3.1 is wildly unpredictable. Sometimes the
model will snap back almost 180-degrees rather than move to where you
want it.
Its almost as if the model is snapping to the mouse position rather than
the nearest model position. You have to rotate in multiple small increments
to avoid the problem.
Anyone else hate this as mush as I do?
G.
Currently using ZB3.1 under WinXP + 1Gb
