Rotate Image Plane Y Distortion in Z
  1. Texture> ImagePlane> Load Image> “T”
  2. Deformations> Rotate Y
  3. rotation causes image Plane to resize “squish” in the Z axis.
sym = Off
Perspective = Off
Maybe try to rotate plane before loading ref picture?
That’s expected behaviour. It’s not squishing, it is rotating around the Y axis (just the same as you would rotate a model for a turntable). If you want to rotate the image plane in the screen plane then rotate it around the Z axis.
Thanks for the relpys.
