Rotate Gizmo precisely
I need to rotate a Zbrush model in small angles. I know that if I activate the ring in the Gizmo and move my cursor away form the center I get more granular control. Is there a way to type in a numerical value or get even finer control of this?
If you click on any of the Gizmo rings and drag while holding Shift you’ll snap to 15 degree increments by default. Set Preferences : Transpose : Rotation Steps to change the snap angle increment. Despite what the button help says, it looks like the snap angle is 90/number of Steps. Max rotation steps is 90 so minimum snap angle is 1 degree.
