Quick question. I created an alpha that I am trying to use. I have set up to use the “roll” function along with lazy mouse. Whenever I first start dragging the mouse the alpha appears cut in half. (left side of image) When I drag in a straight line the alpha keeps repeating over itself and builds up a ton of thickness. (middle image) When I try to drag on a curve the image streaks over itself and blurs out (right image)
I have tried making all kinds of adjustments (roll distance, lazy step, etc) along with initializing my tools. No matter what I do the alpha always starts off cut in half and repeats. Even when I’ve spaced it enough that it doesn’t fully overlap when I run on a curve, it still starts off cut in half and repeats. I’ve tried using standard brush and layered and have issues with both. The alpha look totally clean when I draw rectangle for a single alpha.
