Hello guys , just finished rigging a humanoid character, I pressed bind skin and noticed that I can only move the upper body with the rotate command, the lower body is static do you have any ideas?
Hello @Yoan_Danailov
It’s impossible to say without you illustrating the issue in some fashion, but it’s probably because either you are not moving any zspheres that influence the lower body, or because the lower body in the bound tool is masked.
