Came here via a google search-- can confirm, so far as I can tell, ZBrush will occasionally just decide to “throw out” the entire undo history of a project. I make time-lapses using the undo history functions, and just today, opened up a nearly finished project to make a video, and the undo history is at zero. It had an intact undo history when I saved it last night, and have never deleted the undo history on this project at any time, because I was making it as a time-lapse.
Not only are my current and backup save purged of undo data, but all the quicksaves of that project likewise have no undo history at all. Which is pretty bizarre. Other projects and quicksaves have their undo history intact, up into the thousands for one long video I had laying around.
I am an advanced ZBrush user, I understand about subtools having their own histories  and all that, yet here we are.  No video for me.
It’s a rare phenomenon-- only happened to me twice before over several years, but it does happen. The first time it happened, I likewise assumed that you guys had changed the program to automatically purge undos on shutdown or something. But yes, Undo histories do sometimes disappear into the ether.
If there an obscure macro I’m accidentally typing that switches off the undos? I do not know. I have found nothing so far in my own behavior thus far that causes this to happen. Not looking for a fix necessarily, I assume the data is lost, but this is a real thing that happens sometimes. No switch to 2.5D, same polysphere, same mode, for the entire sculpt.
Edit-- the problem seems to be tied to the file, not the subtool. Copying the subtool and re-pasting it into a new project saves the undo history from then on normally, but does not restore the old lost undo history.
I also now notice that the “Skip Quicksave” toggle is on for my file, which explains the lack of backups, but I swear I did not toggle it that way. This was the first time I ever even opened preferences on this project. Checked the default polysphere projects to see if it somehow got checked there in those files, but couldn’t find anything there.
Enable saving is toggled on for the main file undo history however, and it still reliably deletes the undo history after every close now. Happy to forward you the file if you like.
Undo settings are default and untouched.
