Restore lost symmetry
Hi, I must have had x symmetry turned off for a brief spell when modelling and have lost a bit of symmetry. One side of my model is ok, the other is not. What would be the easiest way of copying over info from the good side?
Thanks,
monks
Using a Mask Brush with a Rectangle stroke, mask half of the mesh (good half) then go to Tool > Deformation and click ‘Smart ReSym’. You can also try ‘Mirror and Weld’ in Tool > Geometry but the good side has to be on the left so if the good side is on the right in a front view then just switch to the back view.
Thanks for the response. I tried that and the resulting geometry is all messed up. I’m working at 6 detail, and it takes about 10 minutes to process the resym. Maybe that’s the problem, But the geometry is so messed up as to be unusable.
Is there a way to do it with Mirror/ weld? Even copying and pasting the good area onto the bad area would be better than losing the symmetry. Is that possible?
Thanks,
monks
