resizing a doc
:slight_smile: hello! i hav’nt enough space on the “ground” side of the document; each time i try resize, the doc is modified in his shape, and i just want to have more space… maybe there is a way… Thank you!
Try the Cropper zscript within ZScript\utilities folder
cameyo
Hi Marcel
Why not all saved as usual for keeping all object, texture etc…
Open a new document with wished size
Re import the export data :slight_smile:
Pilou
The easiest way to do what you’d like is either with the Cropper script as suggested or with the Document>Crop button. This resizes the canvas (either larger or smaller) without resizing the pixols on it and can be used to create more room in which to work.
The Cropper is included with ZBrush 1.55b.
