Novice here, but i am making anatomical models from work and they need to be specific dimensions for 3D printing. I have watched many videos and read many posts but none seem to work.
I have tried to use the scale master- set the scale- sliders to subtool size- then change sliders- then hit resize subtool.
Either it doesnt change anything at all or it changes 2 of the 3 axis and makes the other tiny so it looks more like a plane.
I have tried unifying- which made no difference.
Many thanks for your help
You didn’t mention it, but did you try 3D Print Hub plugin in the Plugins menu and setting your size there?
Thank you, yes I have. I’ve been back and forth from scale master to 3d hub. But still can’t resize, or specify dimensions.
I always use 3d hub before exporting to print during other models. ATM I’m doing a rounded edge tapered elongated cube- that fits inside another piece so the dimensions need to be right and it just won’t change to the sizes needed. ( I’ve also tried size in geometry- that partially helps at the beginning but not exactly)
