Reset view for imported head that is at an angle
I imported a head that is at an odd angle. I want to line the head so when I rotate it with the shift key the head is correctly lined up. How do I do that?
Hello Bill.
If you’ve imported the head at that angle, then the only thing you can do is manually reposition it, via Gizmo/Transpose.
If the head is symmetrical, you can restore symmetry to it by positioning it at the center of an axis as best as possible, and using Tool > Geometry> Modify Toplogy> Mirror and Weld. It may help to switch on the floor plane to visualize the axes (make sure the elevation is set to Zero in the Draw Palette).
