Request: Alt mode for "mirror and weld"
Hello all.
I don’t know if this was addressed before or if there is actually a better way to do it but I find it really annoying to go to deformations>mirror and then use “mirror and weld” to properly mirror my models when i forget to use symmetry or if I want to make sure everything is perfectly symmetrical. It would be really handy if mirror and weld command worked the opposite way (mirroring right to left instead of left to right) when ALT is pressed.
That would be very useful. Maybe we will see it added in a future update.
Good idea! To suggest anything I should use the “Request” in the title?! Because I want to suggest any things too.
I wrote a script to do just this. You can download it here >
Once installed you can find it under Zplugin > E tools > Tool > Force Mirror And Weld.
It Mirrors and Welds your tool on the currently selected axis, at the selected SubD level; regardless if there are SubD levels or if part of the mesh is hidden. Mirror and weld will also work on both the positive and negative axis
