Reproducible crash
Can someone else try this and see if it crashes: Draw some spheres. Make another layer on top of sphere layer, import a BMP alpha, use depth brush and try to spray a few over the spheres. It crashes my normally robust system every time. If I use a supplied alpha (a NON-imported one} everything is fine. Is there some weird secret I don’t know about importing alpha? Is this a Z2 bug? Sunspots? Aliens?
I am, by the way, running nothing but ZBrush.
Peej
I gave wrong info in above message. Above problem crashes just ZBrush, not my whole system. ZB gives its little “ZBrush Executable has encountered a problem and needs to close. We are sorry for the inconvenience.” message.
The sphere layer is important. It works OK without the sphere layer.
Peej
:frowning: …Peej, you right. I have tryed two times your steps and i had two crash…
Don’t worry…someone will eliminate this bug.
(Maybe incorrect pointer… :wink: )
cameyo
As per the announcement at the top of the Questions and Troubleshooting forum, please provide your full system specs whenever asking any kind of technical question (including reporting errors). We need that information in order to be able to troubleshoot and/or help.
Sorry Aurick,
i have the following system:
Windows XP Professional sp1
Pentium IV 3Ghz
2Gb RAM DDR 400 Mhz
NVIDIA Quadro FX 1000
2 Hard Disk 80 Gb Serial ATA
cameyo
Pentium IV 2.53 G
MSI 845E Max 6566E motherboard
1 G memory
Invidia
Windows XP hone Version 5.1.2600
NVIDIA GeForce2 MX 200
