Hi, is there any other setting for exporting a higher resolution (alpha) depth map when saving, beside using the basic the create alpha from map?
Thank you…
Thank you…
Hi @tom356
You can also use “From mesh” in the Alpha palette which will allow you to make a 2048 x 2048 (max) alpha then export it from Alpha palette.
Thank you, is there a way to save the alpha with transparent background instead of black?
Not that I’m aware of, but would be easy enough to do in whichever image editor you use.
